New Car, Need Sub Recommendation!
I have a simlar post in the speaker forum, I'm going to have 6.5' Comps in my doors, and a sub. I was recommended the PG RSD Comps, so I'll probably go with those. My amp is a bit weak, it's an Orion 4004, so I'll be feeding 200w RMS to the Sub @ 4 ohms.
Are the PG RSD subs worthwhile? I cant' find an RMS value only a max output value (which screams budget brand, but i've heard only good things)
I was also looking at
Polk GNX124 (mostly because of this auction) http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=330190484539&_trksid=p3907.m32&_trkparms=tab%3DWatching
JL AUDIO 10W1V2
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=200173938329&_trksid=p3984.cWAT.m240.lVI
JBL GTO804
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=150186401249&_trksid=p3984.cWAT.m240.lVI
Looking for one around 100$
700 watts RMS... If I powered it fully with my amp, Installed hamster wheels in either side of my boot and built a small nuclear reactor and put it into my car, I wouldn't be able to power it to it's full potential. How about something around 150-200w RMS :p
This looks to be in the right power range-
Memphis 15-MS124D - Memphis 12"
# RMS/Peak (W) 200/400
# Sensitivity (dB) 88
# Magnet Size (Oz) 50
# Mounting Depth (in) 5.5
# Double roll polypropylene surround
# Carbon fiber cone
# Dual flat spiders with graduated rolls
# Single or dual 4 ohm voice coil
# Vented basket and vented spider spacer
# Aluminum heatsink
Our Price: $105.99
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=5253
Funny... I assure you, 200W will make it sing.
If you don't believe me, head on over to diymobileaudio.com and do a search.
...better yet, go over there and ask which subs they recommend to compliment a 200W amp.
I bet this one gets recommended more than any other.
...Another safe bet is an IDQ
Regardless though, it's a bit out of my price range, and my budget is fairly tight (It also has to be ebay or someone that takes paypal :p ) I had an IDq before, it was ok, but I'm ready for something new and exciting!
Well I found some PG's on ebay, so I'll go for those, what do you think of the system
Orion 4004 Amp (2x 50w For speakrs, 1x Bridge 200 watts Sub)
PG RSD Comps
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=250191153452&_trksid=p3984.cWAT.m240.lVI
MEMPHIS 15-MS124D
http://cgi.ebay.com/MEMPHIS-15-MS124D-12-SUB-BASS-DUAL-SUBWOOFER-MCLASS-NEW_W0QQitemZ250191344272QQihZ015QQcategoryZ18803QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
+ Sealed enclosure, What do you think the size of the box should be? Memphis recommends Min 0.9' and Optional 1.3 (Not sure what the optional means though)
aleksander_t
aleksander_t
Vancouver BC
aleksander_t
