New build about to begin
GAMEOVERCCA
INCRIMINATOR AUDIO
1,860
Hickory NC
Everything is out of the land rover.... Now the fun begin's..
Down grading to only 2 batt's in rear and 1 under hood, less amp, but more efficient box and fresh subs
3 Deka Intimidator 1000amp 100ah AGM's
MMATTS 3500.1D on the sub's
2 15 Death penalty's
2 Incriminator comp set's
Eclipse 32440 on the 2 comp set's
New amp rack and enclosure designed and ready to start building this week
3rd deka installed, had to do alot of cutting and drilling to make this fit.. stock battery box and spare tire jack mount is no more lol.. well worth it..
yea the size on thoughs side pockets worked out well.. ill take more pics as build progress's its going slow right now.. can only work on it in my spare time so... but box peice's are all cut, might work on putting base together today. still have to cut the amp rack out. and i got more wiring to do..
will do, its been pouring rain the past few days so i mainly only been working inside on the back up of customer work i have piled up, but i will be back at this build today through friday so... we see how much i get done..
what do some of you guys use to seal your boxs with? i have used liquid nail, window caulk, wood filler.. couple diffrent things.. what do you guys think works the best?
silicone, or silicone adhesive... you have to wait for it to dry before you mount the subs though.
yea that window caulk i used before is silicone.. there is no rush so dry time is not a issue.. just wanna use something that will be the best for the long haul.
16
936
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
876
Currently Audison amps 500.1 and 4.300 with kappa 90csx 6x9 component set. Pair of morel 6.5 rear and a single 10” alpine type R.
947
GAMEOVERCCA
INCRIMINATOR AUDIO
GAMEOVERCCA
Hickory NC
CAT MAN
    May 18, 2024
    May 16, 2024
