skylineTT 10+ year member bass=sekz 4,419 15 Houston/Dallas May 12, 2012 #16 Lol are both RCA's plugged into the amp? Idk if maybe some stuff went loose when you changed the boxes out.
goingdef 10+ year member CarAudio.com Veteran 2,909 26 Norfolk VA May 12, 2012 #17 did they get wired back to the same ohm load? because if there wired at a higher ohm it will make a difference.
OP KJThaDon 10+ year member Member 109 0 Westland. Michigan May 12, 2012 Thread Starter #18 Lol are both RCA's plugged into the amp? Idk if maybe some stuff went loose when you changed the boxes out. Click to expand... Already checked that, thought the same thing but they cant get pushed in anymore lol did they get wired back to the same ohm load? because if there wired at a higher ohm it will make a difference. Click to expand... Ya same ohm load @ 1.33. I always make sure I double and triple check my wiring before i put them back in but **** who knows maybe ill take them out and check them tomorrow again
IonRL205 10+ year member DJ h4z4rdes 2,513 30 Abilene, Texas May 12, 2012 #19 What freq are you playing that it's louder at?
OP KJThaDon 10+ year member Member 109 0 Westland. Michigan May 15, 2012 Thread Starter #20 Figured it out one of the terminals came loose...it was running at 6.5 ohms lol
