new box, how to wire?
brafferty
I got a new box that is dual chambered, no terminals on the box, i originally had them hooked up to a mono set up with my single chambered box but can no longer do so since there is a split in the box, how can i do this? they are 2 dual 2 ohm subs at a 2 ohm final
If ur amps a mono it's internally connected so just hook both woofers up at 4ohm each woofer and ur amp will see a 2ohm load.. Just use 12v woofer wiring diagram or Rockford wiring wizard to wire it up proper.
cool i wasnt sure if i could still get a 2 ohm final, but the amp does have 2 channels, but its advertised with a .1 with confuses me haha, i should be fine to wire through the ports?
Your amp does not have two *channels*. It has one channel with two sets of terminals to make it easier to wire multiple subs in parallel. The two (+) terminals are shorted together, the two (-) terminals are shorted together. If you connect a 4-ohm load to one set of terminals and a 4 ohm load to the other set of terminals, then the amp sees a 2 ohm load.
brafferty
brafferty
idaho
audiobaun
