New battery or alternator?????
u should match the amps of the isolator to how many amps ur system is pulling. THere is a equation to find out how many amps, but i dont know what it is.
The isolator will be good with ur stock batt and alt
Your batteries will not drain faster because you have 2. It'll last longer because you have two. The demand of the system will be shared between them //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif
And unless you plan on playing your system for 30+ minutes on a regular basis with your car off, you don't need an isolator.
will i have more of a problem with 2 batts, then one if i listen to my music with the car off for like 20 mins, without a isolater? two diffrent opinions........ can i get a third? haha
ok so im only 18, and just got some new tires for my 2006 civic ( 80amp alt) and i dont have enough money for both the high output alt and a new deep cycle bat. stupid tires!! Which will help my voltage drop issues the most? i did the big 3 with 0 guage...... and am still getting mad voltage drops ( sub actually skips bass lines and cuts in and out, and its not getting a clipped signal ) My amps are the kicker kx1200.1(1200 rms) and a little orion amp for my comps (60x2 rms ). i could either get a new high output alt, not sure what company to choose from : (. or get a new deep cycle battery and ditch the stock one and run the stock alt. or keep the stock bat upfront with the stock alt, and run a deep cycle in the back. Which option will solve my problem????? i hate when i turn my system up and the bass lines cut in and out.//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Avoid the inevitable, I would get the second battery first and then take it from their. I have 2 batteries, big 3@0gage going at 3000wrms, stocked 110 alt. My lights don't even dim and my voltage doesn't drop under 12.5
Any deep cycle battery will show good impovement over a stock battery. I upgraded to that battery and noticed a difference. Voltage wouldn't drop as badly and it can last much longer. Also less strain on your alt to recharge it.
UNDERGROUND_BUM
UNDERGROUND_BUM
HAWAII
jrwalte
vegang
vegang
