jmanjr
Banned
Well I wish it where that easy to wire at 1ohm an get the max power from an amp, but here are a few factors (hopefully to help you understand) There are factors such as box rise and imp rise which change the resistance the amps sees changing the power output, example: you wire at 1ohm and have 0.5ohm rise your amp sees 1.5ohm load so your seeing less power then you would at 1ohm thats why people wire at 0.5 etc to try an account for the rises you will see, there is really no other way around it, you play a sub the coils get warm the impedance changes your resistance goes up...if you need more elaboration feel free to ask or use the search feature to get more info, if it were me I would buy a dual 1 to try and factor in some rises, should get you closer to that 1ohm load you want.
