New amp. low output?
brandontw
just some guy
I just got my planet audio PA_2500d, I plugged it all in, and the output is barely audible at all.
Tried new set of RCA's, no change, I also disconnected my four channel amp and listened to just the subs, and it was very strange, it was audible, but then I cranked it a little, and it got louder but didn’t sound right at all, the subs were moving quite a bit, but the sound wasn’t like bass, it was just like a moving subs sound, odd.
All wires are fine, messed with all level adjustments and crossovers, no difference, messed with the HU adjustments, no difference, tried on a different output from the HU--nothing.
I have 2 dual 4 ohm RF hx2’s, wired to 2 ohms a piece, then bridged for 1 ohm to the amp, they are both in separate sealed boxes with a volume of 1.25 CU.FT.
sounds like the polarity of the subs is messed up. try reversing the pos and neg of sub "b"
so + goes to +"a" and -"b"
and - goes to -"a" and +"b"
it works for my kickers...
hmmm, im not sure what you mean, theyre dual voice coil, so i wired VC#1+ to VC#2+ then to the amp+ then VC#1- to VC#2- then to the amp- then repeated for the other sub
just take speaker #2 and swap positive and negative at the amp. it might help //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
yes so put + from speaker one to + on the amp and - from speaker one to - on amp.
then put + of speaker 2 to - on amp and - of speaker 2 to + on amp.
its a matter of polarity some amps react different i am sure if squeak was here he would tell me why.....
i dont know the reasoning for it either. but my subs the kickers on sub goes from + to + on the amp and one goes form + to -... it is so hard to get shit straight when dealign with pos and neg.....
if i hook it up + to + and - to- it does exactly whats your do. move alot but no real bass from them....
hehe i was just pointing out that you say you have the 4 ohms //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
was going to quote but figured he would reread it.
brandontw
just some guy
brandontw
Reno, NV
themainjam
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
