New amp gets super HOTT
Yeah I think I'm going to turn down the sub from the deck a little. The gain on the amp is only half way up. The amp says it does 1650 at 1 ohm. And 1400 at 2 ohms. Maybe I should rewire to 2 ohms
clipping it, turn the gain down. it cant put out enough power for your sub clean. check the voltage at the amps terminals when its fully loaded. keep it above 12-13v
Once gain is properly set, should be good all day.
Also....where is the amp mounted? Does it get adequite air around it? Proper use of wiring for the amp?
Extremely well grounded. Its the st1650. Running it at 1 ohm. Maybe I'm pushing it too hard. Could I be clipping it and not knowing it
If it's wired to 1 ohm you can't wire to 2 ohm
What coils is the sub?
My63bug
My63bug
Vacaville ca
youdoofus
