New Amp and sub magnets getting super hot
Amp specs state 1 ohm min load with 4ga supply with 60amp fuse.Make sure your subs are not sitting below a 1 ohm load,Bass Boost OFF,Loud buttons/levels OFF.Check coils on ea sub,.Whats your electrical like???You have enough supply to push that amp correctly?Big 3 done?AGM battery/1or 2? Stock alt or high amp alt?What size is your supply wiring to amp from source/battery?Pics of settings on amp/what subs are you using and ohm load/rms factor.More info needed/Pics
All stock electrical. 95a alt. I read if its 1500rms or under u don't need to upgrade batts and alts??? I'll get pics tonight. Subs are kicker cvr, 4ohm DVC 400rms each. 4gauge ofc, I have an 80a fuse in it. I was wondering, can I Bluetooth a test tone thru my iPhone and set the gain like that?
You can, but check that your device has all eq settings flat and get a true 40hz 0db test tone.
Iphones tent to clip the signal at full volume on device volume so when testing leave the iphone bluetooth volume at 95% or less or else burn a cd with the mp3.
Sent from my Z970 using Tapatalk
complete and utter clipping. Pull out a Digital multi-meter and monitor voltages. Every car is different with its electrical system so probably yours cannot handle the current amp. Or the shop fucked up your gain settings.
imagejpeg_0_5_zpsee5nap0w.jpg.html
95lincdog
95lincdog
portland, OR
95lincdog
