New Alternator
vincer20
Pa
OK i have a 2001 dodge neon with a 83amp alt, i can get a 150 amp alt from a pt Cruiser for 139.99. My question is will this be enough for 1 aq 1200d and 1 aq 4x90? Oh im going with a yellow top up front and maybe a kinetic hc600 in the trunk.
If you are going with a Yellow up front, simply buy a matching yellow fro the trunk. Mixing a Yellow with an HC600 is not a good idea. And, the HC600 is too small for that setup. It is only rated at 600W and you will be a little over 1500W. Either go with two Yellows, or go with two HC1400.
vincer20
vincer20
Pa
vincer20
