You need good sensitivity plus an Fs of well below 100 Hz to get the right "mix". The trade-off is less loudness vs cone area if you still want midbass from these speakers. The mid-woofers I've used and recommend for a lively SQ front stage is CDT HD-6. You can cross these at 80 Hz but on 200W+ per driver you may need to bump that up, and definitely use a 24 db slope.I'm trying to find a good 2 pairs that can do good low end as well because I enjoy midbass as well but enjoy vocals as well. Just want them loud as hell, I know it's a lot but I'd wait for a good set. Flutes have good, but once I get into the 53's, I don't know how well they will hold up.
i head the new HD mids rival the older ES6s. is that true?You need good sensitivity plus an Fs of well below 100 Hz to get the right "mix". The trade-off is less loudness vs cone area if you still want midbass from these speakers. The mid-woofers I've used and recommend for a lively SQ front stage is CDT HD-6. You can cross these at 80 Hz but on 200W+ per driver you may need to bump that up, and definitely use a 24 db slope.
http://www.cdtdealer.com/rubyserv/item.php?id=hd6
Rival in what way? ES-6 has better midbass potential than HD-6, while they're both designed for use with a small tweeter. I wouldn't recommend ES-6 in this case due to the sensitivity being 4 dB lower.i head the new HD mids rival the older ES6s. is that true?
in SQ. in definition..Rival in what way? ES-6 has better midbass potential than HD-6, while they're both designed for use with a small tweeter. I wouldn't recommend ES-6 in this case due to the sensitivity being 4 dB lower.
I'd be fine with 100hz. Just would reinforce it in that way. I am trying to stay with a 2 way system without having to do kick panels or anything like that.100hz and up is easy to find loud good midrange. I haven't really seen high efficiency mids that play lower than that. But if 100hz and up is ok with you there alot of good options.
Sent from my LG-H910 using Tapatalk
These have been recommended to me:I'd be fine with 100hz. Just would reinforce it in that way. I am trying to stay with a 2 way system without having to do kick panels or anything like that.
I'd get the PRV if in my budget.These have been recommended to me:PRV Audio 6MR500-NDY-4 6-1/2" Neodymium Midrange Woofer 4 Ohm
They look sweet.
I ended up getting these though :
https://www.amazon.com/DS18-PRO-NEO6-Neodymium-Midrange-Speaker/dp/B01AJ2UJ7W
I very happy with them. Super loud and clear. Has handled power at every level I have thrown at them. Took a shot and it worked out.
Link?I am running two pair of anarchys in a two way active setup and am pretty happy with them, Upper midrange is a little lacking but got lower end crossed at 63hz most of the time and down to 50hz sometimes. Midbass is strong !
Need a higher sensitivity.Anarchy Woofer DIY Sound Group
There are Beasts but need deep doors to fit them in.
