New 42-volt Batteries
Will you like the new batteries?
  • Yes
    Votes: 4 50.0%
  • No
    Votes: 1 12.5%
  • I'll have to think about it (why?)
    Votes: 3 37.5%
  • Total voters
What do you mean if you could sleep? You on no dose? Heh that stuff is $5.00+ a box. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
- pe@ce
Originally posted by Jmac This just means 12-volt amplifiers will drop severely in price (Yay) but it also means that I won't be able to buy anything new in the future (Boo) ...
By the way, your example is flawed :p
If you make 50 watts with 12 volts @ 4 ohms, you should make 175 watts with 42 volts @ 4 ohms :p
Power is volts squared over ohms. And a bridged output circuit doubles the voltage (4X the power).
Check these numbers:
14 volts bridged gives 49 watts peak, 24.5 watts rms @ 4 ohms
42 volts bridged gives 441 watts peak, 220 rms @ 4 ohms.
No need for power supplies in amps any more lol. The 2 ohm speaker will go the way of the dinosaur.
So will amps be able to go below 1 ohm or is there the same heat factor? More possiblities, more subs/amps, more competitors, more bass, all the fun... //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Can't wait for my 42-volt!
- pe@ce
Originally posted by Jmac While you are correct in stating that the square of the voltage divided by the resistance is technically correct, you must also remember that it's the AC voltage going to the speaker that is the correct voltage to use, not the power source :p
If your theory were correct, every head unit would produce the same wattage per channel ...
Actual output depends on the design of the output stage. My numbers assume zero losses across the output transistors. Maximum theoretical peak-peak output is the supply voltage X2 with a bridge configuration.
With modern BIFET transistors, power amps can come within .1 volt of the rails. Note that the peak output of nearly all head units is in the 50 watt range. Give or take a few depending on what supply voltage they rate them at.
jer_stud56
jer_stud56
Caraudio
jer_stud56
BP1Fanatic
BP1Fanatic
