Well I have Aim, MSN, and Yahoo. My names are below if you got any of them on there, if not thats fine.Originally posted by SPLThunder umm let me check for aim.... im in Phoenix on my dads computer
Power is volts squared over ohms. And a bridged output circuit doubles the voltage (4X the power).Originally posted by Jmac This just means 12-volt amplifiers will drop severely in price (Yay) but it also means that I won't be able to buy anything new in the future (Boo) ...
By the way, your example is flawed
If you make 50 watts with 12 volts @ 4 ohms, you should make 175 watts with 42 volts @ 4 ohms![]()
Actual output depends on the design of the output stage. My numbers assume zero losses across the output transistors. Maximum theoretical peak-peak output is the supply voltage X2 with a bridge configuration.Originally posted by Jmac While you are correct in stating that the square of the voltage divided by the resistance is technically correct, you must also remember that it's the AC voltage going to the speaker that is the correct voltage to use, not the power source
If your theory were correct, every head unit would produce the same wattage per channel ...
