Never hooked up a system
Micmar28
i recently bought 2 12" Memphis refrence subs off a friend, i just orderd a Infinity Reference 1600a Reference Series Class D Monoblock Amplifier along with a Kenwood stereo. my queston is what type of wireing do i use, and what ohms to i run them at.
You will need RCA cables, a 4 gauge power wire (fused) and ground and a remote wire ~12-14 gauge speaker wire should be fine for the remote and sub wiring. That amp is only stable down to 2 ohm. It will depend on your subwoofers coil configuration as to what ohm you can/need to wire the subs at.
look around on ebay for audio pip 4 gauge wire. i think you can get a 25ft roll for around 15 dollars. you will proboly be looking to spend 50 dollars to get everything right.
no just no audiopipe is **** wire. Invest good money in your wiring you will never regret it knu or stinger hpm.
Micmar28
Micmar28
Ada, OK
murph
