Northeast Region NESPL 2010 Rules discussion
CT,DC,DE,MA,MD,NH,NJ,NY,PA,RI,VT,WV
if you are capable of doing a 155+,i bet u can afford a better headunit,if not atleast a better remote.slate,earlier in the thread you talked about coming to oswego to compete with mcvay,what were you running at the time,and what kinda scores were u seeing?
thats not what i was getting at what i really want to know is can you plug the hole where the stock radio goes and on top of that if you got up to 155+ they might not be able to have anymoney for a secont head unit
I see what Smokey is saying, he wants to know if you can plug up the hole the radio would leave if you had to remove it. The answer to that would be no, because without being in the No Wall or Super Stock classes you can't remove the radio from the dash.
Like Slate said though, if anyone was going to come close to a 155 they'd already know for sure. Also, a 155 doesn't come easy, or cheap. To get to that level chances are you'll already be in the No Wall class where you're allowed to have a radio outside the vehicle. If your in any of the Super Stock classes you can remove the radio from the dash, it'll be up to you if you use that radio for burps, or just buy a better radio and use that one.
This will be something everyone needs to address on their own too, because dB Drags won't allow you inside the vehicle over 140 db, and TNESPL has a150 db limit. So be ready for the 2010 season, because rules will be followed. If anyone hits higher than the limit on their first run, then their score will be capped at that limit. So if you hit a 142 in Drags then your score will say 140.0 and you will have to step outside the vehicle for any additional runs.
Yes, stuck in my laptop that needs repair. Hope you're not doubting me. I'll try to post a picture later this evening that may put your suspicions to rest.
no doubt at all,im better with vehicles then names,lol.so im just trying to find out if ive met u or not
ok so if your in no wall doing 49s all year then step up in to 55 with a mircal i am just speakin in genral not happening just a what if this happens. now can the hole where the radio was be pluged some how to repsent the radio being there after it was removered for a burp. then back for daily use
Defj, the only time I was in your area was this:
Smoke, that would be a "true miracle". You could buy a cheap head unit for $60 or $70 bucks or go to a pawn shop and buy a se one.
SPL Blazer
SPL Event Promoter
SPL Blazer
Peabody, Massachusetts, United States
boom24
