neg - (run) from front to rear
what kind of car?
If its Full frame, then grounding to the frame ion the rear should be ok, may not be optimal, but I doubt you would have any serious problems
If its unibody than Id def do a negative run front to back
how long should i go with a dry cell and wet cell batt connected and if i do a run from front to back should i also ground it to the chassis in the rear
you could groud it and the amp(s) to the same place, may help you out some
does this help???
jdmferio13
feayfm
jdmferio13
Central,PA
KINGDELL91
