Needing help subs make a weird cracking noise
are you running the amp mono or stereo?...if stereo, you are only using 50wrms, assuming the amp is not overrated, which in actuality, you might only have 20-30 watts of power available per channel. How much of that is not distorted, who knows?...the manufacturer states THD as
you see where I am going with this....the crackling could be from just about anything with that amp, from my perspective. Could be a single strand of speaker wire touching something, could be a faulty rca, could very well be just the amp in general.
Nah I checked it out it was the box, i took the subs out of the box hooked up each sub to a different channel its a 2 channel amp which is not good for these subs. I need to get a mono block
TheRealARW
TheRealARW
Austin,TX
TheRealARW
