Needed,More Than 4 8's
hallertau2000
I have 4 Boston G104 8's in 1.2cu sealed box its downfiring under the larger side of the rear seat of a F-150 Supercrew running of a Zapco 6.0.I installed Dayton RS225 8's in the doors and now I'm in need of some more LFE Bass.
I could probably squeeze about 1.5cu for another multiple down firing box or 2.0cu for a single woofer in the corner.
I'm thinking 3 tens? sealed or maybe 1 15? 1 uber 12 ported?IDK
any thoughts/ suggestions?
Thanks
Can't help but believe that your enclosure is too small for those subs and that will play a huge part in them not giving you the output that you want.
Nah
Boston specs call for 8.5L or .30cuft Gross its a small *** box woofer that sounds great just does'nt cut the mustard on LFE, that's why I want a little more.
Yes, the Epics do look nice, I listed Zapco so I figure you could go from there on Budget;)
Truck
hallertau2000
hallertau2000
El Cerrito
helotaxi
Mike Mccabe
