Need your opinions
This is another board that I am considering
Here are the specs @ 13.8 volts and 1%THD
670 @ 4 ohms
1140 @ 2 ohms
2000 @ 1 ohm
Signal to noise: 100db
90% efficiency at 4 ohms
Frequency response: 15-250hz
Tell me what you think.
Here is the low power amp I am considering.
Here are the specs
OUTPUT POWER(RMS)DC14.4V:
900W/1ohm @ THD+N=1%
1000W/1ohm @ THD+N=5%
500W/2ohm @ THD+N=1%
300W/4ohm @ THD+N=1%
THD+N:
FREQUENCY RESPONSE@-3dB(UNIT:Hz):10-200Hz
Subsonic(UNIT:Hz):15-50Hz
Signal to noise(UNIT:dB):>95dB(A Weight)
Dimension(UNIT:mm):270(L)*240(W)*45(H)
Here is the middle power amp I am considering.
Here are the specs
Out put power(THD:1%):14.4v
Load 4Ω:500W
Load 2Ω:850W
Load 1Ω:1500W
Signal to noise ratio:100dB
Frequency response:15-250Hz
Subsonc Filter(12dB oct):15-50Hz
Efficiency(load 4 Ohm rms at 100Hz):85%
Total Harmonic Distortion:0.01%
FUSE:35×3A
tell me which amp you would like to see produced because i don't have the money to produce all of them. the 900 RMS will be around $200, give or take, and the 1500 will be around $300, give or take.
Anonymous
Anonymous
Cantonment, FL
Anonymous
NorthFramingham
    Jun 30, 2026
