Need your help on kicker kx 2500!!!
I just got one yesterday and hooked it up and it works great! Thank god! Hope it stays that way forever, but I need to hurry up and get my install goin in my other car because the way its installed now its not fused at the amp, just at my batt, and that worries me.
Yeah that amp will not run at 1ohm, so ive heard and its only rated at 2, I wouldnt think it would blow but just go into protect. Measure the speaker wires at the amp with a dmm to determine the resistance, then youll know for sure if you have it setup right.
If he is using it on this setup and has 4 D2ohm subs they would need to be at 1ohm or 4ohm if I am thinking correct.
http://www.caraudio.com/forum/showthread.php?t=284424
Correct!
im not running them anymore i installed new subs... brutus's dual 4's so i could ran this amp at 2 ohms.. right now im running 4 12" dual 4 brutus subs.. i got the 4 dual 2s forsale! so im at 2ohms.. there shouldn't be a problem.
im running 4 dual 4's at 2ohm.. i bought new subs cause i knew this amp was 2 ohm stable! ive tried 2 other amps and they both worked so something is wrong with this thing
Well I'd like to see pictures of all 8 in that case then cause it seems funny how you'd be able to get 4 brutus 4 ohms seeing as you paid me monday. And why wouldnt you just get an amp to run at 1 ohm in that case?
i bought 4 subs off dennis on here and have 4 subs that i bought locally! why dont u look on some of my threads of my trying to sell the 4 dual 2 subs that i have! i will get my money back if this isn't resloved.. i paid through pay pal.. tomarrow i will take pics of the amps insides cause something is wrong with it!
volt meter said 2.1 when i check it at my buddys house.. thats the first thing he said... this is getting way to complicated.. the amp dont work!!! bottom line
Xtremebass5
Xtremebass5
il
denali804
