Need to figure out the best way to go wiring up a highs amp
c_elliott
So my set up as of now is this...
-Pioneer 6600bt hu Pioneer DEH-X6600BT CD receiver at Crutchfield.com
-Pioneer TS-G644R all around Pioneer TS-G1644R 6-1/2" 2-way car speakers — for 6-1/2" and 6-3/4" openings at Crutchfield.com
-Pioneer GM-D8601 Pioneer GM-D8601 Mono subwoofer amplifier — 800 watts RMS at 1 ohm at Crutchfield.com
-1 Kicker l5 12 dvc 2 ohm. 600 rms
I'm looking at adding a Pioneer GM-A4604 for the highs. Pioneer GM-A4604 4-channel car amplifier — 40 watts RMS x 4 at Crutchfield.com
I do have a couple questions before I get into this. I've never done a highs amp. Since my hu only has 2 rca outs, which one is being used for the sub. 4 channel amps use 2 outs, correct? So 1. do I run the one set back and then run a splitter to use all channels on the amp?
Now my 2nd question. I am running the recommended 4 gauge to the mono amp, with a 100a inline fuse. The 4 chan amp uses 8 gauge wire. Do they make a distribution block that goes 4 in to a 4 and 8 out? Also am I looking at running another inline fuse?
If I have to I'll just go to crutchfield and have them redo everything for me. As much as I don't want to. Any suggestions or answers here guys before I venture that route?
the amp has an option for 4 channel input or 2 channel input. so you can just use the front RCA outputs to the mid/highs amp and the rear RCA outputs to the sub amp (then use fader to help sub level blend).
yes, you can get a distribution block - you don't need it to be fused since the amp has fuses.
Should I add a toggle switch to remote wire to the mono amp? Asking this since if I hook up the 4ch amp the right way I lose the ability to cut the subs on and off through the headunit. And if I do then it will cut off the highs on that channel also.
My other question is when doing the 4 chan amp How much speaker wire is a safe amount to get if I'm mounting the amp in the back with the mono amp? 2002 durango with 3rd row (not up or used, will stay down)
c_elliott
c_elliott
Crozet, VA
keep_hope_alive
