adjetta
Okay so I purchased a mechman 270 amp alt for my 02 infiniti i35, I ran 0 gauge ofc from alt to battery positive, battery negative to strut tower, alt mount bracket to battery negative, and still cant find a good engine to frame ground...but my alt is not putting out impressive numbers. At first I had issues with belt slippage while under load even though i bought a belt that was 0.5" shorter, so I went down another half inch and it seems to be doing the trick but still at idle under load it bogs down to 12.5 if I run my heater, headlights, and heated rear window...I no longer hear it squeal, but I don't think it should drop this low regardless, so I wonder if the belt could still be too loose or if I have electrical connection issues, i'm afraid to drop it down further due to potential stress on the alt pulley bearings.
Its been charging at 14.4-14.5 typically, it will drop to 14.1-14.3 at idle after I start driving, and at lights 14.0-14.2, all of this is if its not under load...with load at idle its iffy, the blower motor and headlights usually doesnt effect it much, but if I turn on a heated seat or the rear defroster it drops down to 12.5
