Need the "Z" of a rockford TRF2212
Product Name TRF2212
Nominal Diameter 12 in (305 mm)
Magnet Weight 400 oz (11,340 g)
Frequency Range 45-200 Hz
Nominal Impedance 2 x 1.5 ohms
DC Resistance (Re) 2 x 1.4 ohms
Resonance Frequency (Fs) 45 Hz
Total Q Factor (Qts) 0.21
Electrical Q Factor (Qes) 0.23
Mechanical Q Factor (Qms) 3.916
Effective Cone Area (SD) 84 in^2 (0.054 m^2)
Equivalent Air Volume (VAS) 0.98 ft^2 (27.8 L)
Compliance (Cms) 6.85E-05 m/N
Moving Mass (Mms) 6.46 oz (183 g)
Voice Coil Diameter 4 in (102 mm)
Voice Coil Winding Width 2.42 in (61.5 mm)
Voice Coil Former Material 8 Mil Aluminum
Voice Coil Inductance 4.32 mH
Force Factor (BL) 26.33 Tm
Linear Excursion (Xmax) 0.61 in (15.5 mm)
Sensitivity (SPL) 92.6 dB
Operating Power (PE) 2000 W RMS / 4000 W Peak
Mounting Diameter 10.813 in (275 mm)
Mounting Depth 8.125 in (206 mm)
found this but this is it //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
there paper work sucks im calculating shit like crazy. i know i had the displacment before but i cant find that right now either. i cant get it to work at all on alpha. im using the basic winisd now.
im shooting for 3.5 cubes after displacements @ 38hz
PioneerSPL1990
IM FER REAL!
PioneerSPL1990
Canton, New York
JimJ
