Need the equation for port displacement
No man for the port not the box
It's the same. Volume of a port is it's displacement in a box
Hypotetical: (totally off the wall numbers not representing a good box)
Box internal 32 X 17 X 15 = 8160 Cu In
The port inside is 2.5 X 17 X 20 = 850 Cu In (the amount of space it takes up in the enclosure or AKA DISPLACEMENT)(include thickness of inner wall when coming up with W btw)
If you want to get really accurate you should include the port wall too (i.e. on a round port, do the OUTER diameter in the calculation).
If you're using MDF walls it can add sufficient volume and you'll need to do a separate calculation for the wall displacement over the port displacement.
KnOkIn It 420
Poo Poo Broussard
KnOkIn It 420
St. Rose Louisiana
swimfreak26
