Need Suggestions for Wiring New System
headshothills
Hey Guys,
I have 2 Memphis M3104D's going in a Newer Ram1500 Quad Cab. Under the rear seat I hasd a custom Fiberglass box built, which is about .63cft. The memphis website says theirs are .50. Never the less, I was planning on pushing them with a Memphis MCD1000. Since they are Dual 4ohm, Whats going to be the best wiring setup? Should I just drop them down in parralel off of 1 set of voice coils to put them at 2ohm, or should Paralel all the coils together to give me 1ohm, shold I Series each one then paralel together?
The all 4 doors will have the Memphis MSQ6.5's in them being pushed by a Memphis MCA300.4 powered by a Clarion VRX925VD.
Thanks in Advance.
Parallel each subs voice coils, than parallel those wires together for a final load of 1 ohm on the amp. That would give u the most power. Or u can play it safe and wire parallel than series for 4 ohms on the amp.
Thanks Phy for the info. I was thinking about going 1 ohm since they will be in a sealed box, and the more power when you run sealed the better, I guess I was just looking for reinforcement that my wiring would be the most effective.
While a sealed box can certainly allow for higher power handling than the same subs in a ported alignment take care that you exceed neither the mechanical or the thermal limits of the subs...
I really didnt have much of a choice, the area in a Dodge Ram1500 only allows so much room, and having a ported box in that area just isnt feasible. But I do understand your comments. The local Memphis dealer is the one that built the box and recommened the M3104D and the MCD1000 amp to push them.
headshothills
headshothills
Phoenix, AZ
headshothills
vegang
vegang
