need sub recommendation
sdwrx
My box is made from 1/2" MDF, with a 3/4" baffle and has approximately .9 cu ft of airspace internally. It can fit any 10" amp that has a depth of less than 7". I've attached a pix and amp specs below. My amp is an older MTX thunder pro. Any suggestions on subs under $120. thx
AMP Specs:
37.5x2 @ 4 Ohm
75x2 @ 2 Ohm
150x1 Bridged @ 4 ohm
280 Dynamic power bridged @ 4 ohm
RMS rating are at 12.5 dc input.
sorry for the newb question... but what's the difference between 150x1 Bridged @ 4 ohm and 280 Dynamic power bridged @ 4 ohm?? I've never heard of "dynamic power". Should I be looking for a sub that is rated at 150 or 280 rms? thanks guys
Too me dynamic power always meant max which to me meant not gonna happen...However I could be totally off. But if your amp is 150wrms@ 4 ohms @ 12.5V then in your car (which will probably be feeding it 13.4-13.8v) your amp should make a little more..
Yes, it seems tht dynamic power is just what the amp might hit for a second or two. It cannot maintain that continuously.
sdwrx
sdwrx
socal
sdwrx
