Need sound help with 1995 Jeep Wrangler
rknight
CarAudio.com Newbie
Hi All,
I installed a new Kenwood Excelon KDC-X304 head unit in my daughters 1995 Wrangler. It did have an updated old radio so not factory original but nothing fancy otherwise just 2 dash speakers and head unit so in mind this was as simple as it gets. Anyways installed the new head unit and all was fine for about a month. All of sudden it did not have any sound on bluetooth, CD, radio, or USB connection. Sometimes when starting up the car it would work and sometimes not for about 2 weeks. I called crutchfield and they figured it was an internal amp issue and were nice enough to send a new head unit which I just installed and I still have no sound. I checked all of the wires in the wiring harness and all are tight and no lose wires. It is possible a fuse controls just the speakers or what would be some things I should look for next?
Weird... I had a KDC-X998 in a `95 Jeep Grand Cherokee. I ended up having to run a new, better ground wire from the harness when mine acted like yours is acting. No issues after that. I hope that is all your issue is. Also... if your head unit is like mine, you can turn OFF the internal amplifier... look into that as it may have been turned off or glitched off some how. If it's off, turn it back on. Good luck.
rknight
CarAudio.com Newbie
rknight
Austin, TX
ThxOne
