Hi,
I own an VW Amarok 2013 (2.0 twin turbo, highlander), I upgraded the stock stereo with follwing,
Headunit: AVH-X4500BT
Front Components: Hertz HKS165
Back Coaxials: Hertz HCX165
Subwoofer: JL Audio 10TW3-D4
Subwoofer amp: JL Audio XD600/1v2
Speaker amp: JL Audio 300/4v3
Atm im using the stock battery (that i dont know the specs), seems the battery slot can fit bigger batteries, it has like a plastic block from the end of the mount to my battery to fit the battery that came from factory.
The only place that i saw some info is Carac, that has some measurements
Height: 190 mm (same as mine)
Length: 354 mm (mine is smaller, around 280mm to what i measured)
Width: 175 mm (same as mine)
Im looking to upgrade the battery over the stock, inside the hood where the battery goes seems it can fit longer batteries, it even has a plastic shim to secure the smaller stock battery, so was thinking on the following, to what i can see have the same placement and similar specs.
http://www.sonicelectronix.com/item_66603_XS-Power-D4900.html
XS Power D4900
Battery Specifications
BCI Group: 49
Cranking Amps: 1075
Maximum Output: 4000 Amps
Amp Hours: 80
Weight: 64 lbs
Dimensions: 7-1/2”L x 13-15/16”W x 6-15/16”H
XS Power D4800
BCI Group: 48
Cranking Amps: 815
Maximum Output: 3000 Amps
Amp Hours: 60
Weight: 48.22 lbs
Dimensions: 10-15/16”L x 6-15/16”W x 7-1/2”H
From what i can tell, the D4900 has the same measurements as the Carac spec, and the D4800 seems to have the same measurements as the stock factory, but wanted your guys opinions into what do you guys recommend?
Thanks for opinions and advise,
XS Power D4900
BCI Group: 49
Cranking Amps: 1075
Amp Hours: 80
Weight: 64 lbs
XS Power D4800
BCI Group: 48
Cranking Amps: 815
Amp Hours: 60
Weight: 48.22 lbs
