Need Some Help Really Bad
dodge_neon_98
OK I've been dealing with this problem for the past two weeks and now I can't stand it. When i took out my old head-unit and put my new one in (wires and everything is hooked up right) the fuses keep popping ( the ones under the hood for the radio), I dont' know whats wrong but it's really irritating me, if someone can help me I would really appreciate it.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif :)
1. Ceck all you wiring again, make sure that there is no bare wires making contact with the chasis.
2. Check your fuses make sure that you are getting the correct rated fuse.
just to make sure I'm understanding this, if you were to unplug the HU and change the fuses, they would be fine until you plug the HU in?
if that is the case, what happens if you shake the wires without the HU plugged in? maybe they are shorting out when you go to plug it in.
dodge_neon_98
dodge_neon_98
Kansas
OldOneEye
BP1Fanatic
    May 14, 2026
BP1Fanatic
    May 14, 2026
