need some computer help
you need to pour water on your harddrive while it is hooked upthen reboot and go to your bios and change the shit.
when it sparks you will know it worked.
your cool.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
ok thanks i have that done but is there a way to keep the actual frostwire program on the external? like the exe. file, and other software? //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Yeah, you can drag and drop the main folder from 'Progam Files' in the C:\ drive to your external. (Example = Frostwires folder would be C:\Program Files\Frostwire, you'd drag that frostwire folder to your external drive.) Your current shortcuts would have to be deleted, and new ones created. You can also choose where to install when you first install the program. You can't just install a program on the external drive, and use it on any computer though. Certain .dll files would have to be registered on each different computer. Which, if you don't know how to change the save folder in frostwire, you may want to do a LOT of reading before attempting that. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif With some programs, it is possible to just drag and drop the program folder to the external and use it on any computer also, but a lot of the times, you won't be able to just simply do that.
Liquid Bass
Midwest Militia
Liquid Bass
KC Missouri
95BlackGA
