Need some advice
UrbanSounds
Hey everyone,
Here is the set up so far.
2 cvx 15s in a custom box/Ported
the subs are wired to 1ohm being pushed by a alphasonic amp.
however the subs drown out the mids and highs.
so i was thinking of getting the following
Clarion eq
Kappa 6.5 Comp front(making a baffle to mount 6.5 and tweet in the 5x7 spot)
Kappa 6x9 or the 5x7 rear
and than another set of tweets on the pillars.
Planning on using the PG Octane 800 4 ch to push them.
What do you guys think. is it a good set up or should I get something else. or maybe swapping out the amp for a fosgate 400.4
Thanks guys
whats you budget?
the Clarion EQ will work.
those Kappa's are ok, you can find better in the same price range as those Kappa's
the amp you have will do fine.
buy a good set of comps Like Hertz.
with the tweeters you should play with the placement & aiming of them, then you might not need a image tweeter.
dont forget deadener
UrbanSounds
UrbanSounds
Orange County, CA
okiedokie
BP1Fanatic
BP1Fanatic
