Need serious help running two amps together one as slave and one as master!!!!!!!!!!!
man_n_da_trunk
ok everyone im almost done i just need some advice from an expert. heres my problem im trying to run my two amps together one as the master and one as the slave. because see the problem is that i dont want to have two bass knobs running to the front. if anyone has like a wiring diagram on how to wire them in this way please please send it to me if not then ill just have to eliminate hooking up the bass knobs all together. a fast response would be nice thanksView attachment 26521888View attachment 26521889
if you have more than one amp in your setup you also have to match your gains etc the same as the other amp, master/slave eliminates that so hopefully you can find a diagram.
on my soundstream and orion's there was a master/slave switch, a cable of some sort to carry signal between the two and the wiring went like so - positive of speaker wire to master positive input, negative of speaker wire to slave positive input, and you jump the negative from master to negative on slave. some amps work this way some dont but its more help than you've gotten so far //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
man_n_da_trunk
man_n_da_trunk
savannah, ga
lostdaytomorrow
