need quick help w/ remote line
stangpounder
Wi
aight this is the deal im putting in a second amp, and i ran 2 remote wires from the same line didn't work. i had the thought of putting the second remote wire directly to the pos. of the battery and put a toggle and a 10amp fuse in the line will this work or fry my amp hit me back ASAP please.
It will work; it won't fry the amp; you don't need a 10-amp fuse, a 1-amp fuse would work fine; and it's still a bad idea. You need to find out why the existing remote wire isn't working. 2 amplifiers shouldn't be too much for a single output. The wire may be pinched somewhere. If you have to use another output, use a key-switched accessory wire instead of a link to the battery, so there's no chance you'll forget to switch the amp off and end up with a dead battery.
stangpounder
stangpounder
Wi
KaeZoo
