Please post pics of item you are willing to sell, (No Corrosion!) I may have a few more bucks to add, for two (2) one each pos+ and neg-. Thanks for looking!
CerwinVegaFan_, Man you must have seen this as soon as it posted, I just blinked, and I had a reply "That was fast." Please post or PM me a picture or brand and model and I'll look it up.
just get some 1/0 lugs from an automotive electronic place if you use side terminals. If you use top terminals theres those ones you can get from any autoparts store that allows you to put the wire inbetween 2 metal brackets and you just tighten it down with a socket.
1/0 lugs are cheaper than ring terminals, and you don't even "need" solder or crimpers at all. just an alan wrench. However I solder my connections too...just cuz I'm that way. Basically man those same terminals on your amp that you can insert 1/0 into and tighten down with an alan wrench, well you can find those at parts stores they work the same as a ring terminal just thicker usually, and you may need to drill into it a little bit to get it to fit on your side post.
