Need opinions to questions about Big 3, Battery, HO Alternator, Amp Kit, etc.
Right now I have 2 Kicker CompVR 15s on a Kicker ZX1500.1 Amp.. I am currently in the process of redoing my entire system with the exception of the amp. I am leaning towards 2 SoundQubed 15s and I'm getting a custom box built. My next step is my electrical system.
My first question is about the Big 3 upgrade. When I perform the big three upgrade, should I use 0 gauge wire and should I replace the currently wire or run it alongside the current wire.
My next question is about a battery. I want to add an extra battery to the system but I'm not sure what kind of battery I should add. I have heard that the Optima batteries aren't very good and I have also heard that it is good to have two of the same batteries.
Also, if I upgrade my alternator, how many amps should it be.
Lastly, I wanted to know what kind of amp kit I should use. I currently have 4 gauge wire ran. I don't know if its true 4 gauge wire or not. But I have heard that my amp is probably starving for power with the 4 gauge.
Please keep in mind that I am not trying to be in competition, I am looking for a great pounding system in an everyday vehicle. I'm not necessarily on a budget but I'm not trying to spend too much.
Any opinions would be greatly appreciated.. Thanks..
1. Use 0 and always ADD to your electrical, don't take out the stock
2. Yes you want 2 of the same....preferably agm because you can mount them in the trunk in any position and there's no harmful fumes.
3.240 amp alt would be plenty.
4. Is it 4 gauge that the amp takes? If so, look at knu fleks kable. Great stuff.
what is your viechle - and your stock alternator ?
its possible that if you got 2 good agm batterys ( get rid of your stock wet cell battery ) that your factory alternator could power the system for the time being.
the big 3 will help lotts.
a 120 amp alternator is on the small side for your amp - but a cheap high out put alternator is no such thing. the cheap ones are pretty much crap - and have terrible output at engine idle - but make their power at 2000 rpms - holding your foot on the gas to keep voltage up while playing a song is pretty terrible - so do a bunch of homework on alternators before you buy a cheapie high out put unit. in my opinion there are 2 trusted names in the game - singer and mekman others have had good results with this and that brand alt - but its all dependent on whos works and whos doesnt.... alot of myth on the net about it too...
i was gona buy a cheapie high out put unit - until i realized the trade off vs a quality unit that costs big boy bucks.
i also use copper welding wire - in size 1/0 avalable from ebay is the cheapest.. i think i just bought exelence... pure copper good thread count and cheap as it getts for new wire.
Ike_Turner
Ike_Turner
Hattiesburg, MS
CSCStang
