Need more power but indecisive!
If you have money for a kx1200.1 new, you have money for a soundqubed 2200 newChoice is a no brainer there the 2200.1D is the superior amp between the two, just keep the gains down, set it via the DMM method and you are golden. Gives you upgrade room for another 12 in the future. hell, why not just build a dual ported 12 enclosure with seperate chambers and add another 12 later that is if you've got the room for it. Plan ahead and save some money on amps and enclosures in the long run because if you are a true basshead, you'll never be satisfied with a setup for longer then a few months.
again, get a hds300 12 d4 and soundqubed 2200.1d run it at 2 ohms for now and in the future grab another hds300 12 d4 wire them both to 1 ohm. make sure you have your electrical system ready for it first though.
Your right lol every time i upgrade a monh or so later im kicking my own rear for not going louder! Guess ill keep it all qubed thanks guys
Oh, are they CEA compliant??
Your right lol every time i upgrade a monh or so later im kicking my own rear for not going louder! Guess ill keep it all qubed thanks guys Oh, are they CEA compliant??
This is now just a BS sticker that does not mean a whole lot. The best amps in the world dont have it.
CEA only test a 4ohm load on a resistor at 14.4v. That dont say much about how the amp will do at its lowest load and real world voltage. A lot like Rockfords inflated birth sheets. You will never see that power in the real world
JonStoltz
JonStoltz
Hamburg, Pa
LosIsATool
