Need loud and clear 6.5s + tweets
JoeK
6x9s are useless in my car, so im only going to be doing the stock tweeters and 6.5's up front.
Basically, what are loud and clear 6.5s that dont break the bank? And what about for tweeters?
I plan on wiring them off of a head-unit until i can get a good 4ch amp later on down the road. Have the factory HU in now thats hopefully going out within a few weeks
[quote name='JoeK']6x9s are useless in my car, so im only going to be doing the stock tweeters and 6.5's up front.
I plan on wiring them off of a head-unit until i can get a good 4ch amp later on down the road. Have the factory HU in now thats hopefully going out within a few weeks[/QUOTE]
There are a lot of good sets out there. What is your budget? Talk to @mylows10 ; he should be able to get you squared away.
[quote name='gckless']There are a lot of good sets out there. What is your budget? Talk to @mylows10 ; he should be able to get you squared away.[/QUOTE]
Maybe $100 for a set of 6.5s, not sure about tweeter pricing.
Well if you buy a component set, that will include the 6.5" mids, the tweeters, and the crossover. What's your budget for everything?
Crossovers now x.x, may just take it to a local shop and see what he can do. Only $20 a speaker in labor
Ok wait, let's start over. Where you are trying to replace the 6.5", are they currently coaxials or part of a component set? Do you have factory ~1" tweeters up front as well, or do you only have the 6.5" woofers? If you already have a component set there, you already have a crossover in there. A crossover is required to run mid-bass woofers and tweeters properly, atleast passively. I don't think you are running active, so you will need a crossover.
If you want to take it to a shop instead of install it yourself, atleast get a good speaker set for him to install. But I would say do it yourself, this is much easier than it sounds. If you can run all the wiring it takes for an amp you can definitely install a component set. Hardest part is getting the door panel off usually.
JoeK
JoeK
Ringtown, PA
quackhead
