oneill584
Hey guys, I got everything installed and it sounds good but I know it can sound a lot better.
I understand which each setting/frequency/gain and everything means, but I just don't know which level to set each one at. Here is my setup...
HU: Pioneer deh-6000
FS: PG RSD
Speaker Amp: Blaupunkt THA275
Subs: 2 Kicker CVR 12's
Amp: Kicker SX 600.2
I listen to every kind of music. From rap to rock to oldies. I know settings are all personal, but I just need to get pointed in the right direction. Also I want to make sure all my settings are safe so nothing clips or blows out.
Here's the settings I need information on...
HU:
HPF-hz?
Equalizer- (+, -) for each hz: 50hz, 125hz, 315hz, 800hz, 2khz, 5khz, 12.5khz
Sub W.2 (Subs) (+,-)- 50hz, 63hz, 80hz, 100hz, 125hz
Blaupunkt Speaker Amp:
Gain
Bass Boost
High Pass
Low Pass
Crossover Switch-Flat, LP or HP
Kicker Amp
Gain Range-4v? 8v?
Temp Max
Volt Max & Min
Compressor: Off, attack, contour, or redline
Phase- Degrees?
Hi Pass- Frequency &Slope
Low Pass- Frequency & Slope
EQ- Frequency, Bandwidth, Boost-Cut
Gain
FS: PG RSD
HU:
HPF-hz?
Gain
Bass Boost
High Pass
Low Pass
Kicker Amp
Gain Range-4v? 8v?
Temp Max
Volt Max & Min
Phase- Degrees?
Gain
