Need insight: Converting Balanced Differential Outputs to RCA Inputs
I've searched through the site and get an error and have researched enough on Google just enough to be confused.
What I need is to convert the balanced differential outputs from my factory HU to a standard unbalanced RCA for my amp. Currently, I'm running high-level inputs to my amp and while it sounds great I'd like to use line level.
While I could purchase something like an Audio Control LC7i or Rockford BLD-2, I would like to attempt a DIY to save money and I don't have any noise that I need to remove in my current setup.
Ideally, I am hoping that someone has done this previously and can provide guidance.
From my research, I see 2 options:
1. Build a simple circuit using an op amp to convert. Should be simple, based on a 12v power supply, and have a flat noise free frequency response. I find many references to this and some high level circuit overviews, but I'm not finding the part numbers listed so I can build it.
2. Build a converter using a 1:1 transformer - this seems too simple to work so I'm hesitant.
Thanks in advance!
-Eric
I think people who really care will buy DSP/converter or replace the factory head unit. If anybody has done what you're talking about it hasn't been done by anyone on this board.
DIYaudio.com may be a better place to find more technical types.
Appreciate your response!
I posted there as well - would prefer to keep the factory HU for cosmetics and integration and wanted to try a DIY for this.
-Eric
Thanks!
Running into integrated high-level inputs on a new Zapco and the sound quality is quite impressive so your advice makes perfect sense.
-Eric
llebcire
llebcire
Iowa
llebcire
BP1Fanatic
BP1Fanatic
