Need info on premier subwoofer
RobertFielding
12" Pioneer Premier IMPP Subwoofer (12" Premier VCCS PRO Component Subwoofer)
yea im buying this subwoofer for cheap off my buddy,
Nickel Coated Foamed IMPP (Injection Molded Polypropylene) Rigilite™ Composite Cone Woofer
Aluminum Insert for Increased Cone Rigidity
Dual-Layer Urethane Surround
Direct Bobbin Mounted VCCS (Voice Coil Cooling System)
Conex Damper with Damper Ring
Lead Wires Integrated into Damper for High Reliability and Improved Power Transfer
Projected Pole Yoke with Vented Pole
High-Energy Ferrite Magnet with Bumped Back Plate
Low-Q Design for use in Small Sealed Box (1.0 cubic foot recommended)
1000 Watts Max Music Power
500 Watts Nominal Power Handling
Frequency Response: 15-2,000Hz
Sensitivity (Efficiency): 88dB (1W/1m)
4Ohm Rated
those are the specs of the subwoofer, im just wondering if anyone has had experience with this sub or one like it. it is coming a the recommended size box 1 cubic foot. im just wondering if it will be better in that box, or a bassworx 12inch vented enclose, the one from futureshop, costs 150, already got that for my other sub too,.
RobertFielding
RobertFielding
Windsor
NewToTheGrounds
Mike Mccabe
