Need Ideas
L337x
wi
I'm looking into a fairly cheap system, i'm a daily driver and i like bass.
What i'm looking into getting is
Head Unit: Planet Audio PI9756
Subs : (2)PioneerTS-W3002D2 Subwoofers 12” DVC2-Ohm Champion Pro Subs 7,000W TSW3002D2
Box : Ground Shaker PBP212 12" Dual Pro Bandpass Subwoofer/Sub Woofer Enclosure Box
Amp : (2) SoundStorm (SSL) EV4000D
Would this all work with the subs i am looking into getting?
[quote name='mylows10']rms of the subs , also a no go n the box or deck either ,get @double 07 ; to make you a box[/QUOTE]
The RMS for the subs, claim to be
RMS Power 1000 W
Peak Power Handling 3500 watt
SSL is not a good idea. They just don't seem to perform as well. Like they are not pushing the power that they say they are to the subs. Now a pre made box. Usually not a good idea to do If your wanting the best sound from your subs. I see that double07 name on a few post about boxes. Some times you can get a custom built box for the same price or some times cheaper then a pre made box. And be more happy about it.
Ok, well do you know any amps that would perform enough to support the subwoofers?
I was going to get 2 SSL's , so 1 can power 1 sub.
If money is an option, I have been installing a lot of the ppi black ice 1,800.1 amps. People buying them used for around $150ish. To me they are a decent amp. I have been looking at skarSK-2500.1D. Found used around $450. Or soundstream RubiconRUB1.2500D. Found used around $270. Those are what I was looking at.
First you need the D4(Dual 4ohm) version of the subs, so they wil wire down to 1ohm. I run those subs and they sound great for the price. I would wipe the rest of that list.
Get a kenwood or pioneer headunit.
Box: Obcon 12" Universal Dual Sub woofer Speaker Box - Ebay
Amp: you cant run much over 1000watt with the factory electrical system. I have a audiopipe aspm 1500watt amp in a tahoe with 160amp alt and the alt isnt even big enough. I recommend audiopipe amps as bottom of the barrel amps.
First you need the D4(Dual 4ohm) version of the subs, so they wil wire down to 1ohm. I run those subs and they sound great for the price. I would wipe the rest of that list. Get a kenwood or pioneer headunit.
You talking about these?
2)NEW PIONEER TS-W3002D4 Champion Series PRO 12" 3500W Dual 4 Ohm Subwoofers Sub - ebay
And a cheap system can turn into a lot of problems. Try not to go to cheap. Hate to see ya get something and have problems. I install for a living. And I see this a lot.
Just remembered, I have that same coaxial/comp set, BNIB, $245 shipped if you are interested. I have the matching coaxials, took these of the...
229
Using Sky High copper OFC wiring and Stinger 8000 series rcas. The US Acoustics usx4085 is rated at 85X4 @ 12.9 volts and proably close to 100w X...
219
That is the great thing about Maestro products, they are very thorough. Downside is the price tag.
415
L337x
L337x
wi
tygar45
    Jun 15, 2024
    Jun 15, 2024
