need help
ok im having some problemy with my system. it used to work fine in my silverado, same battery and samy type of alternator.
subs are 2 12" punch hx2's
amp MA audio 1500x1
subs are hooked up at 1 ohm
kenwood deck forgot the model number but its a motorized face if that helps any.
here is the problem i am having. when i turn the deck up to 25-30 where i normally listen to it at the highs will cut out when the bass hits hard.when i turn the radio back down the highs will start playing again. now keep in mind when the highs cut out the bass is still going. all highs are stock and are bring run off the deck. all wires are soldered in, so there are no stupid connectors. i never had this problem b4, and its really anoying.
any help would be really apricated. thanks Rob
I have the same problem, but its not all that noticeable. My alt is 120 amps or so and wiring is pretty big so I don't know what the problem is. I'd like to find out too. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
bigrob21
bigrob21
New Orleanse, La.
johnecon2001
