Need help!!!
  • 2
yroc434
Va
ok my sy set up is as follows.....
Head Unit... Pioneer DEH 4600bt
Subs......... (2) 12'' Alpine SWR 12D2 wired @ 2 ohms
Enclosure... Ported
Amp.......... Hifonics BRX 2000.1D (1400 watts rms @ 2 ohms)
Here is how i have the setings on my Head Unit:
Subwoofer Control... 100hz : 0 -24
Bass Boost............ Zero
HPF..................... 200hz -24
SLA..................... +1
Fader.................. Center
Balance............... Center
EQ Settings......... Flat
Loudness............ Low
Sub Woofer......... Normal
And here is how i have my amps settings..
Gain.................10'oclock ( 9v to your far left and 0.2v to your far right)
Phase .............. Zero Degrees
Bass EQ............ Zero
SSF.................. 25hz
LPF.................. 29hz
i need to now where to set these settings!!!! NEW TO CAR AUDIO SO ALL HELP APPRECIATED!!!! MY BASS BARELY HITS UNLESS I HAVE THE VOLUME WAY UP ON MY HEAD UNIT (45+)
youre probably gonna smack me for asking this but how do i know if they are bottoming out? im new to this car audio but learning a lot.... i have a disc with tones from 30hz to 300hz im guessing check it the 40hz or 50hz tone?
694
967
934
yroc434
yroc434
Va
yroc434
Decebal
    Jun 10, 2024
