Need Help?
It is still starved and a battery will not completely get rid of voltage drop. It has more to do with the efficiency of your wiring. Fix the wiring and you may not even need the battery yet
You need to set your gains correctly with a digital multimeter and test tones, an o-scope or DD-1. Are you using bass boost on the amp or "Loud" on the headunit? Make sure to turn those off also set the eq flat on the headunit
Never use bass boost it only adds distortion to your system in order to make it louder. This puts stress on your electrical and your equipment also. Just set your gains correctly with everything flat you will see a more stable voltage this way
Brandon9
Brandon9
michigan
robert420
