Boogie Knights
Alright I've tried trouble shooting this on my own, and I'm all out of ideas.
I have a sundown 1200d amp and two 12'' AQ sdc 2.5 stock headunit
About a month ago my subs would start going out at random times.
I'd lower the volume and they'd start up again.
Then they would go out and wouldn't start until I restarted my truck.
I did notice that the amp would go into protect, but after a few minutes it would come out.
And everything would work again. Now as of two weeks I get no sound from my subs.
And the amp isn't in protect mode. What I noticed was after I disconnected both cables from
the battery the amp/subs worked after I turned off the truck no more sound.
Now things I did.
Checked RCA's / switched RCA's
Checked the ground
Checked the power cables - they were loose at the battery and fuse ( fixed it )
Removed the subs from the box made sure connections were good ( they were)
Checked the LOC all working fine.
So does any one have an idea what the problem could be.
Now things I did.
Checked the ground
