need help with wiring...
mm_55
ok, i have a rockford fosgate 700S amp (700 watts). i'm looking to get a wiring kit, but i don't know what all i need. the amp says it needs 8 guage, so i'm guessing that i need an 8 guage wiring kit. is it possible to go with a 4 guage kit, or would that not turn out too well?
i have 2, audiobahn A1051Q subs (dual 4 ohm voice coil, 2 or 8 ohm operation). in order to max these subs out i need to wire the amp up so that its running at 2 ohms (350x2) or 1 ohm (700x1). which one should i go with? 1 ohm?
also would a kit with this wiring be all i needed? (excluding the power and ground wires)
http://www.ikesound.com/Prod_Details.asp?Prod_Id=535
or
http://www.ikesound.com/Prod_Details.asp?Prod_Id=531
i'm retarded when it comes to this, please help me out...
As far as the subs to the amp, you can go either way. You can wire the subs themselves in parallel then run them each to their own channel, or run the subs themselves in parallel, then parallel to each other, then bridge the amp for a mono load. The former method is a bit easier.
As far as a wiring kit.....you could also do either, although I'd probably go with 4AWG, since the price difference is negligible, and it's better to be safe then sorry.
http://www.knukonceptz.com/detail.asp?product_id=KOLAK4
if i went with the 4AWG wouldn't i still need a ground and power wire? it says on the amp specs to go with the 8 guage anyways...i'm ordering the amp from this guy, so i figured i may as well get my wiring from him too...
this is the amp...http://www.rockfordfosgate.com/ez2/ModelInfo/ModelInfo.asp?ItemKey=10058945&CategoryDesc=Punch%20Amplifiers
these are the subs specs...
AW1051T
Power Handling: 300 watts R.M.S.
Frequency Response: 28Hz - 1kHz
2” 4-Layer ASV Voice Coil Dual 4 Ohm
2 Ohm or 8 Ohm Operation
so does it really matter if its wired 2 ohm or 1 ohm? the amp's only like 175x2 @ 4 ohms...
mm_55
mm_55
Missouri
mm_55
