need help with wiring RCA cables
brybry354
i plan on wiring 2 10" subs to separate amps.
right now i have 2 subs to only 1 amp and just 1 RCA cable plugged into the amp.
my question is...do i need to connect another set of RCA cables from my deck into the new amp or can i just leave the 1 RCA cable into 1 of the amps??
im really hoping i dont have to connect more RCA cables because i have a bose system in my 05' chevy silverado and as you all know it is a PAIN IN THE A S S to mess with bose because the factory stereo doesnt have RCA inputs so i had to add a RCA input adapter and it only has 1 set of RCA inputs
If you buy another amp, most have a set of outputs so you can daisychain the amps together to avoid running another set of 16' cables. Just buy a 2' or 3' rca set and hook the amps together.
Look on your amp now, or a picture of it, next to the rca inputs is a set of rca outputs. You connect the amps together by connecting the first amp's outputs to the second amp's inputs. If you don't understand I can find a pic or draw you a doodle or something.
so take the RCA cables i have now and plug them into amp #1 inputs, then take a short set of RCA cables and plug them from amp #1 outputs to amp #2 inputs?
brybry354
brybry354
Texas
brybry354
