need help with wiring configuration
okay im running two amps one for subs and one for comps, also im going to be running 4 speakers off one 4 channel amp. i need help wiring this crap up cause right now its definatelty not working properly.
Is the sub amp a 2 channel or mono @ what ohm is it stable to in stereo or mono? Is the sub a single or dual coil and @ what ohm? this will help out GREATLY if you need some info and/or a point in the right direction.the4 channel amp should be straight forward as far as the comps fo but if nothing os working then check you power,ground,and remote wires...go from there first and make sure you get power to the amps, then go from there. it can/will be VERY frusterating sometimes BUT it's well worth it when you figure it out and it's all said and done with...IMO.
okay my sub amp is a 2 channel 2 ohm sterio stable. the subs are wired in a series making a 2 ohm load, they're 2 ohm dvc kicker cvrs. on the remote cables i have to remote wires running into one input in the ack of the hu one to each amp. for the ground i scraped the paint off the frame but im not sure its a good spot?
You got mail homebiscut.................//content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
aight ill hit you up sometime possibly tomorrow after i test everything out, i need help with tuning my amp so bad im a total noob at tuning.
j_alexander
j_alexander
Tukee, AZ
j_alexander
ThxOne
    May 13, 2026
