Need help with what tools I need for box build
ls2poweredgoat
Womanizer
OK I'm going to attempt my first box build today, I already started a thread requesting what size box I should put my DB500 in....
These are the tools I have...
-Black and Decker circular saw, with laser beam guidance (like $50 at Walmart)
-2 sets of saw horses
-Makita cordless screw driver
-Porter Cable DA sander
-Level
-And the L shaped yard stick thing
Besides the obvious, such as the mdf and the wood, along with screws, do I have the right tools to make a decent box?
dont forget glue
Yeah I forgot to mention that too.
I just don't know how the hell I am going to get a 4 x 8 sheet of MDF home. None of my friends have trucks. I could have HD cut the sheet in half, but I just measured my trunk and it's not 48" wide.
if you had air I was gonna say nail gun but..
how biga box? Home Depot sells the sheets in 2ftx4ft sections too, it might be 3x4 but anyways those should fit in you trunk/hatch, they are easier to work with too
I wouldn't trust a circular saw to give you perfect cuts everytime. I have had some very bad experiences with them being not perfect cuts...........(Probably my shakey hand).
If you can get access to one, I would suggest using a table saw, and take that circular saw back to Walmart.
I know the circular saw isn't the greatest, but it's all I have access to. It has a laser guided beam, which actually helps out alot.
I was thinking this box....http://img29.imageshack.us/my.php?image=25cubes32hz3125sqin0zp.png
It'd be for a DB500.
i always cut straight with a circ saw, of course I dont freehand it, I have a 5 ft level and a 3ft, make your mark, measure from the blade to the end of the flat metal part, clamp the level that distance. Straight every time. Acts the same as a table saw except you move the saw not the blade. Just takes longer to clamp up all that stuff. The ;evel acts as a fence like on a table saw. Speaking of if you can afford it grab some pipe clamps.
Could always just use and uncut edge of the mdf as a straight edge as well . Just clamp it down tight and remember to account for the blade gaurd and blade width //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
i have done that too, any straight edge really, I just dont trust some old peice of wood i find, but I have used wood, angle iron, an old box, whatever
Thank you, I did check the ground and and fuse holder wires and everthing is fine. All I did was swap amps and the previous Alpine pdx sounded...
58
718
986
952
ls2poweredgoat
Womanizer
ls2poweredgoat
Port St. Lucie FL
bjfish11
