Need help with new box plz
thats the volume with the sub and port, and i just wanna make suire it sounds right! also could i do 2 smaller ports on each side instead of 1 port?
Yes two smaller ports on each side should work if you do the math right, but why make it hard on yourself if you can just do one. You not that experienced yet. And this is for you kicker L7 correct?
Well what you just mentioned will work for sound quality. If you did two ports, Just make sure they both add up to the 1 port that you was going to use, then you wouldn't get port noise.
jerod187
Banned
jerod187
british columbia
jerod187
